Check Engine Light
Old Feb 1, 2003 | 10:06 AM
way_too_fast's Avatar
way_too_fast
Thumbs up Check Engine Light
I have a 96 ford ranger with a 4.0 and the check enqine light is on I used a scan tool and found out the codes were that the third cylnder has a misfire and that it is lean I replaced the plugs and wires and erased the code then the light came back on. I was wondering if any one has had a simar problem. It seems to misfire in reverse badly I checked the compressinand that was fine. THANKS
Old Feb 1, 2003 | 01:00 PM
amp17757's Avatar
amp17757
Check Engine Light
The fact that only ONE cylinder is misfiring (running lean) would suggest to me that there is a problem with that one injector. I would suspect that the injector is clogged, but it could also be that the injector is getting a bad signal. I wish I could be more specific ... I'm not very well educated in the electronics that control fuel injection. If getting the injectors is cheap or free, I'd try that first. If that doesn't work, find someone who is quite the FI expert. GOOD LUCK!
