clogged oil pickup screen?
Old Feb 1, 2003 | 09:42 AM
paul c. w.'s Avatar
paul c. w.
Unhappy clogged oil pickup screen?
I have a 1990 e350 with a 5.7 with 130000 miles. It was recently over heated. While being over heated it lost oil pressure. I shut down immediatly, changed oil and got out a lot of debris in sludge.I flushed engine with diesel fuel,then changed filter and oil .The truck was fine for 15000 miles. This problem happened again, but after doing same, the oil pressure comes up to normal for about 1 min. and then drops out /or drops out on acceleration.Someone told me the threaded oil filter nipple goes directly to the pickup screen is this accurate or does the hole below the nipple go to the pickup screen. I thought to blow diesel or air through it.
Thanks Paul
