1994 Brake Drums
Old May 10, 2010 | 06:16 PM
1994F2507.3L's Avatar
1994F2507.3L
1994 Brake Drums
would brake drums off an 85 work on my truck? they both have the axle thing that sticks out about 6 inches
Old May 10, 2010 | 06:47 PM
oreocreaming's Avatar
oreocreaming
yes, same sterling 10.25 axle
Old May 10, 2010 | 06:56 PM
PLC7.3's Avatar
PLC7.3
Not sure what the brake shoe width on the 85..... but I would think the 94 is wider. There are 2.5 and 3 inch shoes.....
Azone sells new for $50-70 each, have you checked the 84s to see if they are even usable within the inner size limits..... There are Max inner sizes too.
Old May 10, 2010 | 07:06 PM
oreocreaming
just make sure the hub size is the same. other then that, same part number.
Old May 10, 2010 | 07:20 PM
1994F2507.3L
the factory drums have probably worn 3/16 to 1/8 of an inch... how much wear is to much wear to be machined?
Old May 10, 2010 | 07:48 PM
oreocreaming
you can call your local brake/repair shop. ask if they turn drums. if so, they will tell you what the least material you can have. then just measure the ones your looking at
Old May 10, 2010 | 09:35 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
They have a "MAX DIA. ???" cast into them ...
-Enjoy
fh : )_~
BoneSS
Jul 24, 2007 06:37 PM
FMG
Aug 16, 2006 07:12 AM
beartracks
Mar 9, 2006 12:04 AM
cbremer
Feb 9, 2002 06:36 PM
paulg
Mar 27, 2001 12:12 PM
