brakes
Old May 10, 2010 | 06:02 PM
little truck's Avatar
little truck
brakes
Hi everyone
I have a 94 ranger 2 wheel drive when i drive it for a while the right front brake starts to lock up. then when i let it sit overnight is frees up! Do you think it might be the front rubber brake hoses colasped on the inside?
Old May 10, 2010 | 10:37 PM
michigan66's Avatar
michigan66
Have you tried checking the caliper to see if it is sticking when the brakes are applied. It may be that all that is needed is to free up the caliper sliders and apply some lube to it. If that is the problem, you probably should do the other side as well.
Old May 11, 2010 | 05:22 AM
little truck
thanks
i will check the sliders this weekend
