bed difference question
Old Feb 1, 2003 | 07:30 AM
Gwilkrrs's Avatar
Gwilkrrs
Question bed difference question
what is the difference in beds from 50 to 51? someone is selling a good 50 bed but i have a 51. will it fit?
Old Feb 1, 2003 | 10:29 AM
mtflat's Avatar
mtflat
As far as I know, it will fit - BUT you will have to use the '50 fenders with it IF it is an early '50. They changed mid year.
The difference in the beds was the raised side panels where the fenders attach. The fenders have a corresponding 'notch' The late '50/'51/52 has flat sides - thus no notch in the fender.
This is what you'll need to watch for.
Old Feb 1, 2003 | 04:03 PM
Gwilkrrs's Avatar
Gwilkrrs
do they look the same? the raised panel would show or not? i would just have to stay with 50 fenders?
Old Feb 1, 2003 | 06:30 PM
mtflat's Avatar
mtflat
Generally the boxes have the same shape and dimensions, but the raised panel sticks out roughly 1/2" from the bedside - it is obvious. It measures approx 13 x 70" with rounded corners.
I'm sure they used the same frame so other than the fender issue it should work within the series: F1 to F1, etc.
Old Feb 1, 2003 | 11:46 PM
dongc1's Avatar
dongc1
The tailgates are also different! Check out the latches and where they are attached.
