Need Help Removing Timing Cover..!
Old May 10, 2010 | 02:47 PM
gta214's Avatar
gta214
Exclamation Need Help Removing Timing Cover..!
Hey, I need to replace the Timing Cover on a Ford 1985 Econoline e-250 I took everything off except the "thing" that holds the fan.. coolant was leaking and it was the timing cover it has a hole and i Need to replace all the cover... Help please.
Thanks,
Old May 10, 2010 | 04:26 PM
bashby's Avatar
bashby
Serpentine or v belts? What engine?
Old May 10, 2010 | 04:39 PM
gta214's Avatar
gta214
Its a 351 5.0 V-belt.. The timing cover is already off and loose but theres a "thing" don't know the name sorry but its the one that moves all the belts its routed to the main engine. its the best i can explain...
Old May 10, 2010 | 04:43 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Water pump?
Old May 10, 2010 | 05:12 PM
gta214's Avatar
gta214
I already took the water pump off. just need to remove that one piece that doesn't allow me to take the timing cover off looking to see if there is a certain special way I tried everything!!
Old May 10, 2010 | 06:09 PM
bashby's Avatar
bashby
Crank pulley maybe? (AKA harmonic balancer) Remove the center bolt (crank bolt) and get a harmonic balancer pulley (autozone has free loaners)
Old May 11, 2010 | 08:46 AM
Rogue_Wulff
I'm guessing you're spot there. What threw me for a loop was the part about "Thing that holds the fan"........
Also, when using the balancer puller, be sure to remove the large washer from the bolt, then thread the bolt back into the crank. Otherwise, you're liable to damage the threads inside the crank and will not be able to get the bolt back in.
PGS67
Feb 23, 2016 05:54 PM
mzimmers
Aftermarket Products
Jun 9, 2015 11:50 AM
Peavey1986
Jan 23, 2015 02:52 PM
dirt_e_rider
2004 - 2008 F150
Dec 21, 2014 05:19 PM
SoCalAngler
48
Aug 22, 2014 01:57 AM
