Fuel Line Questions
Old May 10, 2010 | 09:33 AM
breedo99's Avatar
breedo99
Fuel Line Questions
My buddy has an 89 F150 with a straight 6. The back tank was removed and discarded. The front tank has two lines coming out of it. One runs from the tank to electric pump then filter then motor. The other one goes from tank to a different filter to back of motor. Is this correct? I dont think it matters but the black thing that controls switching the tanks is not hooked up anymore either. Let me know if this is correct or if we need to change something.
Old May 10, 2010 | 01:56 PM
breedo99's Avatar
breedo99
anybody know?
Old May 10, 2010 | 02:28 PM
subford's Avatar
subford
That thing on the back of the engine is the Fuel Pressure Regulator (FPR).
He could have driveability problems if he is not using the black thing that controls switching.
He dos not need one that switches but he may need the reservoir type that is on the one tank F-series, Broncos & BIIs.
It could cause problems on hills and when going to WOT.
Old May 10, 2010 | 02:36 PM
breedo99's Avatar
breedo99
other than that are the fuel lines run correctly? i didnt remember my 88 having another filter on it nor two diff fuel lines on one tank????
assuming WOT means wide open throttle????
Old May 10, 2010 | 07:08 PM
subford's Avatar
subford
Sounds like they are ran right.
Should only have the one filter on the frame by the high pressure pump.
Yes WOT means Wide Open Throttle.
There should be two fuel lines (supply & return) and a vapor line for a sum of three going to the tank.
fp_5
Oct 24, 2021 12:07 AM
SSellers
20
Dec 24, 2013 12:47 AM
predaina
29
Mar 29, 2011 07:07 PM
spikedog
Aug 28, 2006 10:02 AM
