heres the problem put the 74 steering column in the 70 today auto w/power steer when i took it ouy of the 74 it only had one rod going to the transn ( the motor and trans were alreadt gone ) this rod is about 18 in long has a 2 in peice of rebar welded in the middle of it well it not reaching my trans shift so there must be something missing what is it ??does any one have one laying around ?? i got a 78 302 w c4 trans
heres the problem put the 74 steering column in the 70 today auto w/power steer when i took it ouy of the 74 it only had one rod going to the trans ( the motor and trans were already gone).
This rod is about 18 in long has a 2 in peice of rebar welded in the middle of it Shade tree mechanic fix-um.
Since you are using a 1974 A/T steering column, the following would have come with it:
D3TZ7326A .. Shift Rod-From manual control lever on the transmission to selector lever on steering column / 18 21/32" long / 7/16" diameter.
Fits: All 1973/77 F100/350 2WD with A/T / 1973/76 F100/250 4WD w/C6.
JST AUTOMOTIVE in Lebanon TN has ONE = 615-443-3086.
