E4OD issues HELP
Old May 9, 2010 | 02:13 PM
myoldblue97444's Avatar
myoldblue97444
E4OD issues HELP
love the site!!! 97 PSD 250 4x4 E40D ext cab longbed 155000 miles. OD goes on and off all by itself when ever it feels like it. Dealer can't pull codes, its not flashing. They think solinoide pack or PCM. It shifts and runs good, just has fits with OD. Any thoughts would be greatly appreciated!! Already checked all plugs and pins from firewall to tranny.
Old May 9, 2010 | 02:34 PM
JamesHajek's Avatar
JamesHajek
Is it possible that the wire in the column is getting hung up or pinched. I know when i bought my truck. The wire was cut in the column. The button was broke off as well. Just a thought. Maybe take the column apart and trace the wire down from the selector and see if its loose or something.
Old May 9, 2010 | 03:05 PM
JamesHajek's Avatar
JamesHajek
I didn't even realize that was your first post. Welcome to FTE!
Old May 9, 2010 | 03:17 PM
Brown Falcon's Avatar
Brown Falcon
Welcome! Sorry, can't help much. But I think James has you on the right track.
Old May 9, 2010 | 03:44 PM
myoldblue97444
Thanks for the quick responce! I did have the column apart three times already and replaced the switch in the end of the shifter. Saw all the wires except where they are in the rod itself. No rubs, cuts, or pinches. I'm about ready to find a 5 speed!!
Old May 9, 2010 | 03:52 PM
Brown Falcon
Check the VSS? (Vehicle Speed Sensor) on the rear diff. Pull it out and clean it off with a clean cloth, then re-install. Check that wiring for wear also.
Old May 9, 2010 | 04:06 PM
myoldblue97444
Didn't know about that one thanks man i'll try it and let you know!!
Old May 9, 2010 | 07:23 PM
myoldblue97444
Ok VSS clean no differance. Dam! DYK will a PCM out of a 2wd same engine work in a 4wd? just to see if the OD thing goes away. Also DYK which solinoide in the E4OD is for the OD, and can it be accessed through the pan, and be purchased indivdually?
Old May 9, 2010 | 07:45 PM
Hussler's Avatar
Hussler
Have you checked the TRS?
What speeds do you see the issue at?
Old May 9, 2010 | 08:10 PM
myoldblue97444
Plug looks good on TRS, happens at any speed,wet,dry,smooth ,bumpy. Even when the key is on and engine is off. I haven't been able to pinpoint any similarities at any of the times this happens. Its just plain wierd!
Old May 9, 2010 | 08:18 PM
bearhugger's Avatar
bearhugger
Try changing out the vss sensor,even if it looks ok,but get it from the ford dealer,about $35.00,sometimes they can be bad even if it looks good.
Jim
Old May 9, 2010 | 08:21 PM
myoldblue97444
Sounds like a good idea. Thanks Jim! I'm new to the site so I don't have the whole thing figured out yet. I'm Jeff in PA. thanks again!
Old May 10, 2010 | 06:40 PM
myoldblue97444
New VSS installed, same problem, seems to happen more when trans is hot. will a solinoide stick? Sometimes when it kicks out of OD if I push the button 10 or 15 times fast it will go out but then kicks right back out again.
