problems with rocker arms
Old Jan 31, 2003 | 10:13 PM
jwtimme's Avatar
jwtimme
I converted from ductile iron ajustable rocker arms to a set of comp cams roller rockers. about a month ago. yesterday the motor started making a lot of racket. took the valve cover off and I had broke a push rod. Upon inspection their were 3 others broke and 4 cracked. The part of the push rod braking is the cup end. The cup is breaking out. It looks like the push rod is rubbing agens the rocker itself. Do I need a special push rod to run these rockers, or are these rockers no good. Has any body had this same problem. I just rebuilt the motor about 6 months ago. It sucks to take the motor out again to chase metal around.
Old Jan 31, 2003 | 11:25 PM
Ratsmoker's Avatar
Ratsmoker
I would call dennis at dscmotorsport.com he sells dove (comp cams) rollers and will be able to hook you up with the correct pushrods.
Old Feb 3, 2003 | 02:37 PM
1pump's Avatar
1pump
Are the new rockers the stock ratio? If their not, that could be the problem. Is this a hydraulic lifter engine? If it is, maybe you got 'em too tight? Just a thought.
