N.O.T normal operating temp
Old May 9, 2010 | 01:13 PM
61fordf25's Avatar
61fordf25
i have a 61 f250, what should my NOT be at? thanks-erik
Old May 9, 2010 | 04:23 PM
Moto Mel's Avatar
Moto Mel
Back then the the usual procedure was a 160 f thermostat in the summer and a 180 f in the winter. Running with no thermostat is a no-no as the coolant circulates too fast to absorb the heat and conduct it to the radiator for cooling. If you don't run a thermostat you should at least run a restrictor to allow the coolant time to do it's job.
Old May 9, 2010 | 11:00 PM
flipklos's Avatar
flipklos
I use a 180 year round and have had no problom in 90+ temps. Just make sure to let it idle after a hard run for a bit or she will spike to 250!
Old May 9, 2010 | 11:44 PM
61fordf25's Avatar
61fordf25
Thanks guys!
