Removing drivers side door panel and would like to know what style clips so I don't break them. There are 2 screws behind lever and one bottom left. Bottom right (hinge side) is very tight like it is screwed but I do not see one. If anyone knows about these panels I would greatly appreciate it.
remove the srews, 1 @ mirror on door, 1 behind hand hold, there may be another down lower?
Anyhow once all hardware is removed Push up from the bottom of the door on the panel. The panels slide into some clips to stay in place, they are not like the older cars which had spring clips. So push up, may need to hit with the ball of the hand but they will go up.
