Engine missing
Old Jan 31, 2003 | 08:14 PM
motobub's Avatar
motobub
Engine missing
My '88 300-6 started missing about a week ago. I changed the spark plugs, and it still does it. What should I look for? It only seems to do it at about 1800-2100-rpms and only when I put a lot of load on it.
Please help
Thanks
Lars
Old Jan 31, 2003 | 08:52 PM
6 cyl boy's Avatar
6 cyl boy
Engine missing
Hello,
Check your timming and check your advance mechanism. When was the last time you cleaned out and lubed your distributor.You might also want to check the coil.
Good luck!
Old Jan 31, 2003 | 10:11 PM
heathdaily's Avatar
heathdaily
Engine missing
This condition occurs when you lose or "leak" spark energy. This energy is usually lost through ign wires with poor insulation. Although it can occur with a cracked cap, coil, etc. The air itself becomes a conductor to move the spark. One of the dead giveaways is that it will always be worse on a humid day as the extra moisture helps the air conduct the energy. The reason that it's worse under load is that electricity always seeks the past of least resistance. When the work in the cylinder becomes too hard it just finds a weaker path.
Try popping your hood with the engine running in a very dark place. Sometimes you can see the ign. wires glowing a funky blue-green. This is the gasses in the air becoming excited by all the lost energy. Just like how neon signs work.
The solution is simple, replace the wires and examine the cap, coil, etc for cracks and/or other places wayward spark might choose to go.
Old Jan 31, 2003 | 10:24 PM
motobub's Avatar
motobub
Engine missing
Thanks I will try it soon. It is pouring down rain today and today is deffinatly the worst its been.
Lars
Old Feb 3, 2003 | 03:31 PM
motobub's Avatar
motobub
Engine missing
I changed the distributor cap and plug wires. I made it better but still seems to miss when I am going slow and floor it. What do you think it could be? I didn't mess with the timing when it happend. It just started one day.
Thanks
Lars
Old Feb 3, 2003 | 07:21 PM
heathdaily's Avatar
heathdaily
Engine missing
Next logical step, I would investigate the coil. Look for cracks and/or carbon tracking. If you have a spare, replace it and see if it affects it.
petrolheadjosh
Modular V10 (6.8l)
Mar 1, 2016 08:04 AM
rtreftz
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sep 15, 2015 08:35 PM
wezol5484
41
May 6, 2014 10:55 PM
srkr
6.7L Power Stroke Diesel
46
Feb 26, 2012 03:10 PM
smus9917
Feb 22, 2009 09:16 AM
