"E" vs. "F" series
Old May 8, 2010 | 08:32 AM
bronkntrukholik's Avatar
bronkntrukholik
"E" vs. "F" series
I bought a '90 E350 4x4 (aftermarket coil sprung solid axle D44) frame that formerly an ambulance, does anyone know if the frames and set-up is the same as the "f" series pick-ups. There was no body, just a 7.3, trans and transfercase. It runs and moves how it is, but was wondering if i could put the pick-up body on this. I didn't know if the body mounts were to far forward or ???? Thank You for any help.
Old May 8, 2010 | 08:35 AM
Diesel_Brad's Avatar
Diesel_Brad
The nose is too short on a van and the cab is too far forward. But if you are up for a challenge
Old May 8, 2010 | 10:08 AM
LCAM-01XA's Avatar
LCAM-01XA
Just drop a conversion van body on that frame, and you'll be having a fairly rare vehicle (not too many 4x4 vans out there).
Old May 8, 2010 | 01:47 PM
broncoderek's Avatar
broncoderek
Ever seen a van turned into a pickup? I've seen a few being used for towing horse trailers. A 4x4 version would be sweet!
http://static.racingjunk.com/63/ui/1...et-MH-titl.jpg
http://www.americandreamcars.com/198...lypkup0908.jpg
http://farm4.static.flickr.com/3219/...7b07ca.jpg?v=0
Old May 8, 2010 | 02:37 PM
George84's Avatar
George84
+1 that would be killer
Old May 8, 2010 | 03:55 PM
LCAM-01XA's Avatar
LCAM-01XA
Even better if he sticks a dually axle under the rear
Old May 8, 2010 | 09:03 PM
bronkntrukholik
Ok, thanks for the info! I'll have to figure out what i'm gonna do now? I was hoping they were the same. 4x4 Vans are sweet!
Old May 8, 2010 | 09:23 PM
cyclegrip's Avatar
cyclegrip
In light of this thread I made this quick pchop
Old May 8, 2010 | 09:26 PM
pintoches's Avatar
pintoches
subscribing
Old May 8, 2010 | 10:19 PM
LCAM-01XA's Avatar
LCAM-01XA
Man, DragRag is gonna e-kill you if he sees what you did to his Pathfinder
Old May 8, 2010 | 11:40 PM
capn kirk's Avatar
capn kirk
Stay with me now cut the van like in the photoshop and keep that part as a removable hard top. That or full length sun roof/rag top? It might fail inspection if you chop it because those may be required support pillars
+1 for a 4x4 van
