Window channel is the vertical flocked lining the glass slides up/down in and seals the top of the pane in the door. Lift channel are the horizontal pieces on either side of the glass that it slides past also called Beltline w.s.
So I'm guessing that the door side weather stripping goes on the top of the door frame and then the upper part of the anti-rattle kit fits into that?
