Downpipe
Old May 7, 2010 | 05:17 PM
Big Ruth's Avatar
Big Ruth
Downpipe
Are you guys doing header wrap or anything on your aftermarket down pipes I noticed the stock down pipe is a lot thinner and has a lot of heat shielding on it so I wondered with it being larger and no heat shielding whether heat is in issue.
Old May 7, 2010 | 05:26 PM
TheTowingCowboy's Avatar
TheTowingCowboy
Lol I was just looking into heat wrapping. Most people dont wrap it but I want to. I hope to get the money together to wrap mine. I think it would be a good idea cause it will in general reduce underhood heat. Also less likely to get burned.
Old May 7, 2010 | 05:38 PM
fordpride's Avatar
fordpride
I pit one layer header wrap on mine.
Old May 7, 2010 | 05:51 PM
TheTowingCowboy
How much wrap did you use Pride? So I got an idea how much to buy.
Old May 7, 2010 | 06:08 PM
427 fordman's Avatar
427 fordman
I bought like a 25' roll of 2" I think it was off of flea bay. Cost me like 25 bucks and came with some metal zip ties. Wasn't the best but it worked. Think it was for a little rice grinder. Had to double up the zip ties to make them long enough. I used it on my hot side ic pipe cause it's so close to the powersteering pump and used the rest on the downpipe only where it's closest to the tranny. That's all I had left.
Old May 7, 2010 | 06:22 PM
Big Ruth's Avatar
Big Ruth
Good info. I live in the Midwest so I wonder about trapping moisture under the wrap.
Although it gets so hot that I can't imagine any water staying to long.
Are you guys wrapping your aluminized downpipes?
For those who have wrapped them, how far down are you going and whereare you starting?
Old May 7, 2010 | 06:27 PM
427 fordman
Like i said, the main place I wanted it was where it was closest to the tranny. I would have done more if I had more but I figured that was the most important place imo. It was kind of an afterthought and wasn't a lot of fun to put on with the pipe on the truck though.
Old May 7, 2010 | 09:57 PM
ccarrier's Avatar
ccarrier
Old May 7, 2010 | 10:01 PM
Big Ruth's Avatar
Big Ruth
Originally Posted by ccarrier
Very nice. Are you using the stainless MBRP exhaust or aluminized?
Old May 7, 2010 | 10:06 PM
ccarrier's Avatar
ccarrier
Aluminized
Old May 7, 2010 | 10:08 PM
Big Ruth's Avatar
Big Ruth
Aluminized
Cool. Thanks for everyones replies.
Old May 7, 2010 | 10:10 PM
ccarrier's Avatar
ccarrier
I wrapped my downpipe the full length and on down to the exhaust system
Old May 7, 2010 | 10:29 PM
kawa's Avatar
kawa
Talking
There is also ceramic coated down pipes. Jose swears by his, claims that it has reduced heat significantly if I'm not mistaken.
Rog
Old May 7, 2010 | 10:58 PM
fordpride's Avatar
fordpride
I got a med. roll from JEGS i don't remember how much was on it. It was something like $35
Old May 8, 2010 | 12:04 PM
BadDogPSD's Avatar
BadDogPSD
Rog
Tymar sells them with the ceramic coating. Pretty sure RiffRaff does too...
