Sounds like a blown fuse to me! Check the fuse panel located directly below the steering wheel to the left, you will need to look at owner's manual to determine the location of the exact fuse. (Sometimes, it's not right either) If it is blown, replace with a fuse of the same size, don't put a bigger fuse in it's place. If you don't find a blown fuse there, there is another fuse box located in the engine compartment but I think those lighting fuses only dealing the trailer connections.
Keep in mind, a fuse usually blows for a reason to indicate there is some kind of problem such as a short or overload condition. If you install a new fuse and it blows again, you will need to find out what the problem is.
