Power steering pump leaking.
Old May 6, 2010 | 03:29 PM
Blade79's Avatar
Blade79
I have figgure out that my power steering pump is leaking. Can anyone tell me should replace the pump or do I need to get one of thoes kits with the seals for it. and is this something I can do myself and how hard is it? Oh yea it's an 89 F250 4x4. Thanks.
Old May 6, 2010 | 05:07 PM
EPNCSU2006's Avatar
EPNCSU2006
I put new o-rings and seals in the leaking pump on my '87. I'm not sure if there is a way to measure the internals for wear or not, but it seemed very similar to the other pump I have out of a '94. The re-seal kit was about $7 when I bought it from NAPA maybe a year ago and was pretty straight forward to install if you have a little mechanical ability. I think the trickiest parts of the job are removing the snap ring and reassembling the pump. Be sure to get or borrow a power steering pump pulley puller/installer tool.
Old May 6, 2010 | 06:29 PM
Blade79's Avatar
Blade79
Thanks I will see if anyone I know has that tool. I was hoping to be able to save some money with just buying the seals. Thanks again.
Old May 6, 2010 | 06:34 PM
fordman1090's Avatar
fordman1090
You should be able to rent a power steering pump pulley puller from an auto zone or any other local auto parts store that loans tools.
Old May 6, 2010 | 07:56 PM
EPNCSU2006's Avatar
EPNCSU2006
I second the AutoZone suggestion. They loan you the tool for a deposit ($30 on the PS pulley puller last time I used one), which is fully refunded when you return the tools.
Old May 9, 2010 | 06:15 PM
ken2400's Avatar
ken2400
I had a leak on a 91 F150 and fixed by removing the fill cap, cleaning around it, and putting it back on. I think the last person did not get it back on right. Take it on and off a few times to get the feel of it.
Good luck
Bigdoon1522
Apr 12, 2014 09:06 PM
Zorfox
Sep 25, 2010 05:40 PM
texcan
Jul 18, 2007 11:54 AM
tomucen
Aerostar
13
Feb 25, 2005 07:41 PM
dazman
1978 - 1996 Big Bronco
Jun 8, 2004 11:30 PM
