flash code 22 and 63 help
Old May 6, 2010 | 11:48 AM
renegade14's Avatar
renegade14
im working on a buddys 88 f250 with a 302 it was starting and staling so i checked for a vac leak and found a few and fixed them but it still staled after starting changed the iac sensor and then it started and idild at 1500rpms and would not *** down so i then replaced the tps just for the hell of it and it still stayed at 1500rpms so i hooked it up to the tester and its giving me a map sensor and tps code any ideas guys?
Old May 6, 2010 | 04:23 PM
ymeski56's Avatar
ymeski56
Der Postmeister
Disconnect the battery for 5 min. to clear the KAM (kept adaptive memory)
Then put some miles & multiple completed warm up cycles on it before re-scanning. You didn't specify if those were active codes, or continuous memory.
Sais13579
Oct 24, 2024 04:22 PM
pipepro
Nov 7, 2013 11:38 AM
2005f-150
35
Jun 12, 2011 09:04 PM
bronco-bud
Nov 28, 2003 07:01 PM
GammaDriver
Nov 29, 2002 01:13 PM
