Picking up a C6 with transfer case today swapping into my 150 with a 302. Trans coming from bronco with 302 I think a 1990. What should I expect doin the swap from a manual.
Its still attached to an engine that was pulled wit 90k. I was debating on chancing it n putting right in. But may get rebuilt first since that's what I SHOULD do. But its not a daily so if it breaks or don't work its no rush in re doing the labor. Just PITA
If the fluid is bright red, I would put it right in. If the fluid is brown and stinks, then it might need some work.
You may need some driveshaft work after the swap, maybe not, I can't remember since there are so many tranny combos for these trucks.
