Lift 2 in on a 79 f150 2wd?
Old 05-05-2010, 08:31 PM
79outlawf150's Avatar
79outlawf150
79outlawf150 is offline
I have a solid 2wd 1979 f150 I want to raise just 2 inches its a bit low for me I know its only a 2wd but I love to get a tougfher look raise it 2in put a roll bar on it. Anyways I cant find anywhere to get a kit cheap for a 2in lift on my 1979 I checked ebay etc. I love the 79 style and front end rear etc. Anybody guide to where I get a 2inch lift front and back??
Old 05-05-2010, 11:06 PM
79outlawf150
Anyone know where I could get a lift kit from thank you
Old 05-06-2010, 01:08 AM
HillbillyDeluxe81's Avatar
HillbillyDeluxe81
HillbillyDeluxe81 is offline
You can't lift it even two inches without bending the I-beams and modifying the steering. You can't simply bolt on a "leveling kit" like you can with a later model truck.
The best option is the Autofab "econo" 3" lift. 65-79 econo lift It's probably more that you're wanting to spend. But you gotta realize it takes more than a polyurethane spacer to lift these trucks.
Old 05-06-2010, 02:12 AM
79outlawf150
Thanks for the reply I guess it stay the way it is lol I been a car guy my whole life. I didn't realize lifting just a few inches cost so much
Old 05-06-2010, 02:20 AM
ChaseTruck754's Avatar
ChaseTruck754
ChaseTruck754 is offline
it's just the suspension that is one these trucks. Since the i-beams have kingpins at the connection point to the uprights/spindles there is no way to adjust the camber after lifting or lowering aside from bending the beam to compensate.
Heck - when they do alignments on these old trucks they bend the beams to get it right. This is time/effort which = $$.
Newer trucks that used the i-beam suspensions went to ball joints where the beams connect to the uprights and the ball joints allowed for use of eccentric cams to correct camber. That's why you can get away with lifting a "never" (I say newer but I beams got dropped for a-arms in 96/97) F series only a couple inches for a lot less.
Going more than 3" with lift on even the "newer" trucks requires a pivot drop bracket or bending of the beam though - and it's about the same cost as the older trucks here.
Old 05-06-2010, 02:20 PM
79outlawf150
It weird though I get the way there built thanks for the insight I'm new to trucks ford really. I just see so Many lifted up front and back guess I'm stuck where I'm at I just wanted 2 inch lift
79 f-150 guy
17
07-14-2021 06:08 PM
caleballen95
01-24-2015 10:22 PM
willmunny79
01-09-2014 03:01 PM
79outlawf150
05-06-2010 02:05 AM
eglaisi2
10-06-2009 08:38 PM
Quick Reply: Lift 2 in on a 79 f150 2wd?
