superchips ??
Old May 4, 2010 | 09:36 PM
1978300ford's Avatar
1978300ford
Smile superchips ??
Superchips Piggy Back Programmers - MAX MicroTuner Are they worth the money to put on a 306 build?? Or would a program chips for the package be better?? tire size change, tranny shift change, ect....
Old May 4, 2010 | 09:40 PM
Bayer-Z28's Avatar
Bayer-Z28
Hand-helds and mail order tunes are fine for absolute basic bolt-ons, gear change and tire change. Anything more than that you can't do much. If you're adding heads, cam, LARGE intake, find someone that will/can dyno tune it. That's the only way to get a true and accurate reading of your air/fuel ratios, injector settings, maf/map settings and numerous other things that effect the efficiency and performance of your powertain.
I'm big on dyno tunes.
Old May 4, 2010 | 11:21 PM
rla2005's Avatar
rla2005
A dyno will get you in the ballpark, but a custom in-vehicle tune with a wide band will get you spot on with the tune. A Superchips mail order tune is probably not worth the money.
