So I am getting around to doing the motor in my 73 F-100 with a 360. I know common thought is to build it up to a 390, but I am satisfied with the 360 as I only use the truck on weekends for projects around the house and work once or twice a week.
#1 I hear 2 schools one says stick with my factory intake and Motorcraft 2100 the other says go to a 600 cfm 4bbl with vacuum secondary, whats your guys thoughts?
#2 outside of the intake the only real mods I was looking at were an RV cam, cloyes gear 9-3108 true roller timing set, and a set of Flowtech 12540flt headers; which I think is a mild enough build to still work nicely with the stock 2100?
Unless you are racing, you will find a fuel mileage low rpm torque cam outstanding. I tried the rv cam and was so disappointed, I took it out.
The economy cam made the engine so torquey where we drive rpm wise that it felt like a diesel. No doubt hp at 6000 went down but power and torque at 3000 rpm was monsterous and made truck awesome to drive.
you are correct... never. Where I am looking to go is open up the 360 a little and still keep it fairly economical, I have a daily driver that gets 36mpg. The truck is for the little hauling of lumber I do for work and mostly fun. From what i know about the 360 the timing set and headers should do that, was just trying to make sure I was thinking right before dropping the $$ on the parts. Also just trying to make sure the factory 2bbl will get the job done with these small mods and that I didn't need to go to a 4bbl.
