2001 7.3 Weak... Help!!
Old May 10, 2010 | 05:46 PM
bluescrew's Avatar
bluescrew
my 06 150 had more HP than my current 350... from what i understand, you need a tuner to wake these engines up
Old May 11, 2010 | 12:57 AM
van_350sd's Avatar
van_350sd
Originally Posted by cavitation
I have a grey CPS replaced under recall about a year ago. My engine runs great but sounds like it is probably a good idea to pick up the updated blue unit. Are all grey units potentially bad, only a limited run, or do all the grey units cause the engine to run less than at its best?
Ford used a cheaper sensor inside the Gray units and they also used a cheap fake gold plating on the 3 pins, the plating is not a good contact and most of us Bead Blasted the gold off the pins to expose the copper/brass pins and it helped a little, but the sensor was cheap and that was the downfall.
So the new Sensor has a better sensor inside and they went back to the Tinned Copper Pins and they work so much better. For 25.00 it well worth it.
One thing I noticed is the AIC/ACPM, with the Gray unit I had 672 RPM at Idle w/80HP tune, and the Blue is 666 RPM Idle w/80HP tune, and I check this after the Rig gets hot and all temps are up. And the Gray CMP would surge and mis-fire and run the EGT's to 1000 doing 45. I will never use another gray CMP, even if you paid me to use it.
Old May 11, 2010 | 10:03 AM
cavitation's Avatar
cavitation
ok, thanks for the clarification. What I still don't understand is what Ford was trying to correct by replacing original black units?
I am correct in understanding that Ford released the updated blue units for 7.3 motors thru 1997?
Old May 11, 2010 | 01:45 PM
Brother Les's Avatar
Brother Les
You have a great truck there and we will all help you walk through this.
When my '01 was running junky it was two different issues
1) bad fuel
2) trans crapping out. You might want to drop the pan and look at the bottom. takes about 45 minutes to drain and drop and return. it will hold about 6 qts
Eponator
Modular V8 (4.6L, 5.4L)
Jun 2, 2025 01:13 PM
bikerman2299
Feb 17, 2017 12:35 PM
jeronlines
22
Sep 4, 2016 08:36 PM
E450 newbie
Dec 5, 2015 11:58 AM
jr_vw2
Jul 9, 2012 04:45 PM
