Wheel bearings shot??
I own an 04 with 6.8l 2wd. I recently noticed a lot of chattering from the front suspension going over rough roads at low speeds. Also noticed the same at higher speeds on the highway. So, jacked up the front of the truck to get each wheel off the ground to wiggle the tire side to side and top to bottom. I noticed some play in both front wheels. Bothe wheels spin freely when in the air and no noises seem to be coming from the bearings. Any thoughts in my problem? Do the front bearings need to be repacked and the retaining nut retorqued? I have nearly 90k miles on it.
knibbeone
1983 - 2012 Ranger & B-Series
04-10-2012 09:48 AM
