Concrete on paint
Old May 2, 2010 | 09:32 PM
reklaus's Avatar
reklaus
4th Gear
Concrete on paint
I just bought a 2007 F-150 that has a few specks of what appears to be concrete on the hood and one fender. Most of them are about 1/8" to 1/4" in size. Any suggestions on removal with out damaging the paint?
Thanks
R.E. Klaus
Old May 9, 2010 | 11:15 AM
rotun's Avatar
rotun
Reads ***** rules!
Muriatic acid, diluted. wet down the area first and don't let the acid solution touch anything that is not already wet! Pour it on, it will smoke a little when it touches the concrete, rinse immediately, try removing the spot. You will see it soften up the bond, may take a few times and be careful, the acid will burn your skin! This is what we used when I was driving concrete mixers and we did it every day, but like I said......keep everything wet and rinse often.
Old May 11, 2010 | 04:45 PM
reklaus's Avatar
reklaus
4th Gear
Thanks. I received the same advice from a friend who works for a major parts distributor. He ask his paint tech people.
R.E. Klaus
