'60 F250 Build
Old 07-20-2010, 09:18 PM
El Jim's Avatar
El Jim
El Jim is offline
Does anybody know which t case shifter was original for the 60 4x4 ? The OP's has the longer "J" shaped shifter, my 60 has a shorter, straight one. Which was correct for the Dana 24 ? ((I'm painting mine skymist blue BTW)
Old 10-09-2010, 09:15 PM
jdasilva644's Avatar
jdasilva644
jdasilva644 is offline
So I've taken a few more steps in the build!!! Finally!... I took some time off to work on my '01 F150 which now has 10" of lift on 37" tires
over the last three days I've worked the lower cowls near the bottom door hinges... They're not beautiful cuz I had to bend all the parts from flat stock and there was nothing on either on of the cabs to go off of so I had to wing it... but they're strong and functional...
as you can see ^^^ I also had to fab up a new cab brace on the drivers side
and fixed the nasty hole you can see a couple pics up ^
I'll clean up and skim the areas that are visible with some bondo! I'm not makin a show truck Haha just wanna drive it around
I also had to patch where the heater blows through the passenger side... I had a tough time with this cuz as I wire wheeled it more holes kept showin up!! so by the time I got to clean metal I just slaped this together to close it up
Then I was able to get the front end back together which was pretty exciting for me...
Tomorrow she gets shimmied around, straightened out and tightened down then a turn of the key!! after some new coolant and the fuel line gets connected
I'll post more as she gets done!! Thanks for checkin it out!
Joe
Old 10-12-2010, 04:03 PM
Tom Lee's Avatar
Tom Lee
Tom Lee is offline
I am really interested in what actually was the original motor color. I have painted mine blue, but am going to have to overhaul it this winter and will repaint it. If the original color is black I will leave it blue. I had been told at one point that the original was more towards a puke yellow. I just ordered some valve cover decals and they are outlined in that yellow. I also need the original air cleaner for a two barrel carb on a 292.
Old 10-12-2010, 09:23 PM
thundersnow70's Avatar
thundersnow70
thundersnow70 is offline
nice looking truck, wish i had the time/money. do you know if it has the 456 gears? if it does you might want to think about taller tires if you are gonna buzz it down the interstate to work. when i got mine it had 235-85-16s on it and would only do about 50-55 mph. now i dont have that problem!
Old 10-13-2010, 06:02 PM
jdasilva644
Pretty sure mine was the "puke yellow" cuz that's what was under all the grime... but some say it was black so I'm not sure if there was a cutt off on the colors or what...
Thunder snow, the plan is to put 35" tires on it cuz it does have 4.56's... But i dont plan on taking it down the highway... not now at least, seems dangerous Hahaha she's a little loose!
Old 10-13-2010, 08:01 PM
thundersnow70
my first set were 36in tsl radials, and it made a world of difference, both ride and rpm, the current set is 38.5 boggers, bias ply, lost a little ride but i think it was a fair trade. people cant believe its a stock suspension. good luck! and for the guy wondering about the shifter, mine is short and straight.
Old 10-14-2010, 12:11 PM
Tom Lee's Avatar
Tom Lee
Tom Lee is offline
1960 Ford motor original color.
I guess we will just have to keep looking to find out for sure. I have been told by other sources that the original color is the yellow, but finding the exact shade will be a challenge.
Old 01-27-2011, 01:29 PM
nice1960f250's Avatar
nice1960f250
nice1960f250 is offline
my first project
i have a 1960 f250 with a 292 but im taking it out cause its my first vehicle and the motor only has 60 thousand orginal miles so i need help putting this 360 in place of the 292 but came into a crossmember problem but just a lil set back but just sayin hey to all the 1960 ford pickup lovers
crazyredneckanyhow
Ford Truck Parts for Sale
04-16-2017 02:31 AM
down2earth
36
09-06-2015 01:35 PM
jdasilva644
19
10-23-2010 09:44 AM
jdasilva644
16
05-14-2010 08:40 AM
AZGUY
58
12-16-2009 10:41 PM
Quick Reply: '60 F250 Build
