Difference in Cylinder heads?
Old May 1, 2010 | 03:36 PM
coolguy1419's Avatar
coolguy1419
I've got a quick question. I was wondering what the difference in air in head and Air in Manifold? I've did some searching on here but couldn't find anything? I was wanting to get another head and port and polish it and get it all ready and swap it onto my truck. Any help appreciated. Thanks
Old May 1, 2010 | 05:05 PM
F-250 restorer's Avatar
F-250 restorer
You might want to put on a head for a 240. That will boost your compression half a point. Of course if you port it, and you absolutely should if you want more performance, then you will need to dial in that carb again.
Old May 1, 2010 | 06:14 PM
dustybumpers's Avatar
dustybumpers
air in the head has the air injection cast into the head. in manifold has fittings, and tubes in the exhaust manifold,the 240 head is a great option, but the efi heads are fast burn. kinda evens out on the compression
