Plugged Radiator
Old Jan 30, 2003 | 05:31 PM
Charlie's Truck's Avatar
Charlie's Truck
Plugged Radiator
First post hope this is the proper place to ask this question. I need to have a new radiator in my truck old one plugged and had a cracked side tank.
When I went to order a new rad. they asked if I had a 1" wide core or a 2" core. Mine only has a 1" core but will a 2" work? I pull a car trailer from time to time.
I have a 1994 F-150
4.9
5 speed
3:55 rear
Thanks ahead of time for your in put
Old Jan 30, 2003 | 07:39 PM
steve83's Avatar
steve83
Plugged Radiator
Yes, the thicker core has more tubes to transfer more heat, but it'll never hurt to have more than you need. Most 4.9s got the 3-core radiator, but the manuals without A/C usually got the 2-core. They should be able to match your original by the numbers stamped into the top of the core.
Old Jan 31, 2003 | 10:26 AM
jim henderson's Avatar
jim henderson
Plugged Radiator
Probably will work, BUT be sure to check for fan clearance. Come vehicles may be pretty tight with either a mechanical or electric fan.
At worst you will probably get bloody knuckles if the space is too tight, but still worth checking.
Good Luck,
Jim Henderson
