GT40 Underway (DONE!)
Old Jun 1, 2010 | 11:14 PM
nashaj's Avatar
nashaj
Old Jun 2, 2010 | 05:21 AM
Bob Gervais's Avatar
Bob Gervais
Looks great! Any plans on taking it to a dyno?
Old Jun 2, 2010 | 08:50 AM
nstueve's Avatar
nstueve
that's awesome man! Eventually when I get Thor all finished up I want to go with GT40 heads, with upper and lower intakes like you did...
Old Jun 2, 2010 | 09:38 AM
PIKE's Avatar
PIKE
Any info on what you used for throttle body?How you did you do your throttle linkage?Did you retain cruze control?Are the 1.7rocker arms a bolt in?I am right at that point with my bronco(rocker arms)and expect mine to apear very similar,stock air box will be used where did you get your intake fittings and tube?Very nice clean install!
Old Jun 2, 2010 | 10:43 AM
nstueve's Avatar
nstueve
Looks like he used 4-5 pieces of Spectre air intake components. I've seen them being used on SPIKE's Power Block TV... Although I can't tell you exactly where and what he ordered... There should be multiple online stores that carry Spectre components.
Spectre Performance - Official Site
Old Jun 2, 2010 | 11:03 AM
BCHauler's Avatar
BCHauler
That looks great. Could you help some of us rookies with a quick breakdown on the parts you used. How difficult was this to do?
Old Jun 2, 2010 | 06:04 PM
nashaj's Avatar
nashaj
I may get it dyno'ed eventually.
The TB came with the upper intake. I bought it off a guy who had it on a mustang. I think it's a stock mustang TB.
The intake tube I bought from checkers about 5 or 6 pieces.
For the throttle linkage I used the stock mounting plate and cables. I mounted it on one of the lower intake bolt/stud towers that the coil and tab/tad solenoids were mounted on. I had to move the stud forward a few holes from its original location. The cruise is connected but doesn't work, I think the bend in the cable is too much for the cruise motor to overcome.
I mounted the coil, tab/tad and egr solenoids on top of the a/c compressor.
I'll put a full parts list on here soon when I get some time to get it together.
Old Jun 3, 2010 | 01:00 AM
nashaj's Avatar
nashaj
They bolted right on with the stock push rods.
Not too bad.... I got a few battle scars from it. Took me about a month. It would have been a lot easier had I pulled the engine. I didn't do that cause I would have been tempted rebuild the entire engine or put a 351 in. The heads are very heavy so you'll need a cherry picker or some kind of hoist to put them on.
Special tools used:
Tourque wrench
Engine hoist
Angle grinder
Remote starter
Timing light
Soldering Iron (pencil type don't waist your time with a gun)
Lighter (for shrink wrap)
OBD1 Code reader
miashley150
Jan 31, 2013 05:44 PM
COBRAjrb
Ford vs The Competition
50
Feb 24, 2004 02:16 PM
Rintin69
Feb 2, 2004 08:44 AM
DT 466Man
29
Nov 16, 2003 05:35 PM
pntrbil
Dec 28, 2001 08:24 AM
