plug and wires tips and recommendations
Old May 1, 2010 | 06:02 PM
Keystonepaul's Avatar
Keystonepaul
Thanks folks. I looked at the long link on the upgrades and bumping the timing from the bronco forum link. Read about 20 pages of it. I get to the rest in time. Seems like something worth trying. I can change the coil, distributer cap, rotor, plugs and wires myself.
1. How about a 15 dollar timing light off ebay for the timing??
2. Ford racing wires- on the long thread on the upgrades there was some debate or question wether they were still making Ford racing wires for 5.8L? anyone know definatively if I can get those for the 5.8?
Thanks for the replies and the knowledge. Keystonepaul
Old May 1, 2010 | 06:05 PM
Hitokori's Avatar
Hitokori
Ford Racing - Spark Plug Wire Sets - SummitRacing.com
Old May 2, 2010 | 07:42 AM
TexasGuy001's Avatar
TexasGuy001
The MSD coil I have looks like this one, but I'm pretty sure it says blaster on it. It looks similar to the OE one.
MSD Ignition 5527 - MSD Street Fire Coils - Overview - SummitRacing.com
Here is the other one that is all red.
MSD Ignition 8227 - MSD Blaster TFI Coils - Overview - SummitRacing.com
I'm not really sure what the difference is. It is probably what was already stated.
Old May 2, 2010 | 07:47 AM
TexasGuy001
I just looked and mine is an 8227 and says Blaster on it, but it looks like the street fire 5527.
Old May 2, 2010 | 10:59 AM
ymeski56's Avatar
ymeski56
Der Postmeister
#8227 Blaster TFI E-coil= 48K output+.44 Ohm resistance+85:1 turns ratio= "Good to Go"! Money well spent!
Old May 3, 2010 | 04:19 AM
TexasGuy001
I definitely would buy it again.
Old May 9, 2010 | 03:44 PM
skyfox10's Avatar
skyfox10
I think some time after 06, MSD changed the blaster coil to the all red design. Because I'm sure that the blasters used to have that black ring.
Old May 12, 2010 | 10:51 PM
skyfox10's Avatar
skyfox10
Ok, so I did the MSD coil pack (8227), MSD cap/rotor (8482), and Ford Racing Plug Wires (M-12259-M301). First, let me say, that if your going to do this, get wires for the lightning, other generic 302/351 wires are too long.
Nextly, I regapped my plugs to .055" from .043" as per the instructions on FullSizeBronco.com - 78 - 96 Ford Bronco offroad club, forums, tech, installs. Now it seems to run ok for the most part... BUT, it seems like, if there is any power gain, it's very minimal , which is what I expected.
What wasn't expected, was that I feel like I lost a lot of power in the Lower Revs. Is this normal?
I was wondering if maybe I overgapped the plugs and am now getting a weak spark, or maybe a slower spark now that it takes longer to build a charge strong enough to jump the gap. Basically what I'm asking is, "WHAT HAVE I DONE?!!"
thoughts?
Old May 12, 2010 | 11:07 PM
86F150302's Avatar
86F150302
Since when are Lightning wires shorter?
Old May 13, 2010 | 01:01 AM
skyfox10's Avatar
skyfox10
well, if you check out the link in my last post, it says that the guy who wrote the article had to swap his taylor 5.0 wires to taylor lightning wires
I got Ford racing wires and they are too long. I looked up the part # I bought, and they fit like every 302 & 351 ever. I think they are generic so they are longer. The lightin wires are just for f150s, so they can be exact
Old May 13, 2010 | 05:15 AM
TexasGuy001
The Ford Racing wires are a little long especially on the 5.0. Like skyfox said, its because they are for 302 and 351.
Old May 13, 2010 | 05:54 AM
lew52's Avatar
lew52
I use the MSD cap & rotor & wires with the blaster coil & autolite plugs , good stuff , i also use the MSD 6al ignition box .....Lew
Old May 13, 2010 | 07:09 AM
  #28
skyfox10's Avatar
skyfox10
Lew, were those autolite copper or platinum? Also, did you leave stock gap or did you regap?
Old May 13, 2010 | 07:31 AM
  #29
lew52's Avatar
lew52
I use the autolite coppers , i use the big plugs because of the 69 heads , close to stock gap.....
Old May 13, 2010 | 08:25 AM
  #30
skyfox10's Avatar
skyfox10
alright, thanks. So is there nothing really to be gained from increasing the gap?
