Dodged a bullet
Old Apr 30, 2010 | 02:25 PM
grams72's Avatar
grams72
Dodged a bullet
I think I might have to go and pick up some lotto tickets,
My trans started leaking fluid so I assumed the worse and thought it was the front pump seal, After changing out my u-joints, thermostat and valve cover gaskets I was going to tackle the trans,
I was unable to budge the bolts so it was going to go to the shop. I looked one more time to verify where the fluid was coming from and it was the pressure line going to the radiator. Easy fix!!!! and I saved myself a few hundred bucks!
Old Apr 30, 2010 | 03:47 PM
kenpobuck's Avatar
kenpobuck
It always pays to check it out completely before tearing into to it. I learned that a long time and alot of money ago lol.
Old Apr 30, 2010 | 05:04 PM
rodneywar's Avatar
rodneywar
X2 on what he said! Same lesson learned here too sometimes it is jut a nut or a bolt that needs to be tightened!!
Old Apr 30, 2010 | 05:41 PM
grams72's Avatar
grams72
u-joints... so like if you dont get the clip to seat, like they will work their way out and then like ruin a lucky day.
Good thing I can get under the truck and fix it in the parking lot to which I had to park her......
