Hey guys is their a way to get my Gas 7.5l v8 in my 250 to smoke like the diesel trucks do ..... is their a kit they use or is it just straight pipe? im running NO cat straight back out in front of back tire ..... if a can smoke it how ... thanks
not really. I know one way but it is not good to do is flood the engine with water an try to start it some times it blows white smoke but never did it just to get smoke.
well i really dont want to ruin the engine i was wondering if their is a kit like diseles use to get somke whenever on demand not just on start up .... so i can **** off people i pass ( because thier pissing me off lol )
i hate to state the obvious but your not going to get that powerful black cloud out of your 7.5l if thats what your after find a diesel and convert your 250. in gas engines black smoke means a rich condition and to get the ammount of black smoke your looking for youd hydrolock your engine first
ok i thought u were telling me that i should literly put in desiel fuel .... and i know it wont be the thick black smoke but i guess your right .... if i want it y try it on a gas engine and just switch to desiel
No diesel will be fine in a gas engine so long as you mix it in low proportion. If you do a mix of 65% gas, 20% diesel, 5% water (vapor, helps thicken the smoke), and 10% used motor oil (extra black). Be sure you run premium fuel for this mix though, as it compensates for the mix so you're engine still runs right. Gives lots of black smoke on heavy acceleration and a bit of smoke on normal driving, also the premium fuel is worth about 15 HP alone, and the water in addition to making more vapor also keep the fuel charge cool for more power. So I figure this blend has to be worth at least 20 HP and the smoke is way cool. Effect is better with stacks and no mufflers.
