Mixture Control solenoid?
Old Apr 29, 2010 | 11:43 PM
buckwhisperer's Avatar
buckwhisperer
I'm new here and glad I found FTE! Have a question or questions about my 84 FSB with 4.9 i6. Problem is my feedback carb is acting up, I believe I narrowed it down to mixture control solenoid, Bronco will not want to idle sometimes, I notice that when this occurs MCS is not "clicking" like usual, so I tap MCS with hard object, (pocketknife), and it will start "clicking" and idling again, so my question is, MCS must need replaced? And if so does anyone have one? Thanks for FTE and any help.
Old Apr 30, 2010 | 10:09 AM
1986F150six's Avatar
1986F150six
Welcome to the forum, buckwhisperer!
I'll take a stab for you. I just looked on RockAuto.com and they have an "Idle speed control actuator" which might be what you are looking for. It is made by Airtex and is part #2H1457.
We have an extremely knowledgable member by the name of NumberDummy who is a guru of Ford parts and their numbers as well as if any are still available and where they are located. Perhaps he will monitor the forum today!
By the way, we also have a forum specific to inline sixes. You might post there as well.
Old Apr 30, 2010 | 11:24 AM
JimsRebel's Avatar
JimsRebel
In the inside bottom of the Mixture Control solenoid there is a plug in connection where the coil is connected to the wiring as thus receives it power. You removing the can by prying the two attach ears; one is shown by the blue arrow in the photo, to separate the magnetic coil. Check and clean the connections on the inside bottom of the can. You can bench test it with a battery charger or maybe even a 9 volt battery to see if it CLICKS each time.
There should be a lot of these used Mixture Control solenoid floating around out there as many have gotten ride of the computer controlled carbs. Try posting on the Ford Six forum if you can’t get yours cleaned up to work OK.
Ford Inline Six, 200, 250, 4.9L / 300 - Ford Truck Enthusiasts Forums
Jim
Old Apr 30, 2010 | 11:50 AM
81-F-150-Explorer's Avatar
81-F-150-Explorer
They also go by the number tag on the carb.
A Feedback Solenoid, (fuel mixture control solenoid) from one carb, may not be interchangeable with one from another as there were several types used. They may look the same, and bolt up the same, but they work different internally. IE: The one on my 1981 will not work on your 1984, but they look identical. The best bet to get the right one, and to save yourself heartache is to get a new one.
Numberdummy will need the ID tag number on the carb to see if he can get you the right one. It may be obsolete.
Old May 1, 2010 | 01:22 PM
buckwhisperer
Thanks for info, I'll try to clean the connections, if that does not work I'll post again. Thanks again for posting back at everyone.
madpogue
May 19, 2017 04:57 AM
Justboy
Mar 16, 2017 12:01 PM
Codeseven
Jan 20, 2017 06:29 PM
AL`
Feb 17, 2016 01:54 PM
MasterMarine
Escape & Escape Hybrid
28
May 14, 2013 08:08 AM
