Fuel bowl leak
Fuel bowl leak
I developed a leak today that seems to be coming from the fuel bowl. I thought it was the drain valve at first but after looking at it better it looks like it may be from below the drain valve. There is a disk that is about 2in in diameter and held in place with a snap ring, this is where it looks to be leaking. Does anyone know if this can be fixed with a new o ring. Or is it a bigger problem? Thanks
Rear of HPOP:
I wanted to get it done quickly so I went to the stealership. The local auto parts did not have it. But as common as the leak is the dealer had them in stock. May have had to pay more but my leak is gone, valley is clean and I am happy now. I need to find the exact size of those o rings, I have a line on a place to get jet fuel o rings that would work just great.
Glad you fixed her up fast Terry. Just for a heads up, because these trucks can spring a leak anytime, anywhere, invest in a Mechanics o-ring kit from Guzzle Bob, Clay sells the kit too and its great to have that kit if something happens, no running around or down time, its in your glove if the enevitable happens..
