Starting Problem
Old Apr 27, 2010 | 10:46 PM
c27schmidt's Avatar
c27schmidt
Starting Problem
I recently bought this 1971 highboy and there is a problem with the starter not disengaging.
When you turn the key to just the on position it turns over and starts but the starter keeps spinning what could cause this?
Ive changed the solenoid check the ignition switch in another truck they are fine.
any help would be appreciated thanks.
Old Apr 27, 2010 | 10:56 PM
714x4custom's Avatar
714x4custom
check the clearence from your ring gear to your starter, fords rairly need shimms but yours might
Old Apr 28, 2010 | 08:06 AM
Victor L's Avatar
Victor L
I got the two small wires to the starter relay criss crossed, and when I hooked up the battery, the starter started spinning.
Did this problem just develop? Or do you think something got hooked up wrong?
Old Apr 28, 2010 | 09:45 AM
c27schmidt's Avatar
c27schmidt
Well it had been sitting for 2 years didnt do it when it was parked then it all of the sudden did it when we went back to pick it up
Old Apr 28, 2010 | 11:24 AM
orich's Avatar
orich
I had this same thing happen while driving down the free way thou,I thought the tranny was going out at first when the starter engaged. Well later found the the key switch plug pig tail wires were all twisted around tight and over time the Hot lead in and the start wire had melted the insulation and fused together that's when the shxt happen.. Well after replacing a few parts that got cooked..I was good to go again..
Ps someone had removed the the little tin cup the key switch set into that keep it from turning.. So found one at the loco pick n pull and install it. That was the fix for me..
Old Apr 28, 2010 | 01:17 PM
c27schmidt's Avatar
c27schmidt
Thanks sure appreciate the help
anied52
18
Jul 22, 2016 04:56 PM
ridecolby
Aug 11, 2009 07:51 PM
f100beatertruck
Mar 22, 2008 07:12 PM
rneutron
Apr 9, 2005 09:46 AM
patmorrison
13
Feb 27, 2004 03:20 PM
