Old Horns
Old Apr 27, 2010 | 07:41 PM
lbrauer's Avatar
lbrauer
Old Horns
Anybody know where you can get some old orignal horns rebuild so they will work. They sure would look a lot better than the new ones I bought last week for my 52 F1.
Old Apr 27, 2010 | 08:21 PM
Julies Cool F1's Avatar
Julies Cool F1
Actually you could probably do the old trumpet horns your self. They have a "blued" steel diaphragm that rusts when they sit. Usually if you clean those and the points off, then follow the "tuning" instructions in the shop manual, they work fine.
I have four of them I reconditioned. The old 6 Volt horns will work on either 6 or 12 volt electrical systems. You just need to be sure that you use a 12 volt Horn Relay. 6 Volt horns on a 12 volt system are LOUD!
The last pair I saw on E-bay went (untested) for $85! Which is a bit much. $20 ea is a good price normally. I know Ilya "51 Panel Man" has (had) at least four of them if he's not going to use them himself. The two red ones work now, the other ones need cleaning up!
Name:  9. Horns.jpg
Name:  9a. Horns.JPG
Name:  E Smaller Horns Replaced.jpg
Old Apr 27, 2010 | 08:57 PM
polarspeed's Avatar
polarspeed
Here is a set for sale -- LOT of Vintage Horns : Includes 51' Ford & 38' Lincoln : eBay Motors (item 230459906091 end time May-08-10 17:35:08 PDT)
Steve
Old Apr 27, 2010 | 09:18 PM
Julies Cool F1
That one marked 51 is off an F-Series - note the bracket. The ones with the rounded backs like that are easier to refurb as opposed to the later style that had flat backs like mine - I used those because of space considerations with the firewall/battery box on the full tilt.
Old Apr 28, 2010 | 08:47 AM
lbrauer's Avatar
lbrauer
Thanks for the information on the horns. I will take apart and see what I can do with these I have first.
haven56
Apr 24, 2013 07:49 PM
GormGorm
Apr 4, 2010 11:21 PM
ridgerider3
Delaware Chapter
16
Aug 15, 2007 10:00 PM
davido
Jul 24, 2002 06:52 PM
the law
Apr 30, 2002 12:11 PM
