Heater core
Old Apr 27, 2010 | 03:55 PM
grip1968's Avatar
grip1968
Heater core
My 98 expy needs a heater core, were should I get it from the dealer or
the local auto parts store (autozone),etc. Its leaking and im smelling coolant inside the air vents.
Old Apr 27, 2010 | 05:14 PM
rtg143's Avatar
rtg143
They take a lot of labor to change. I get mine from a radiator shop that pressure tests them before I take them. It's worth the extra cost to me. I've installed some before that and had to take them right back out with a crack or bad solder point, even though I tesed them at the shop and they checked good. The radiator shop has a special method for testing them.
Old Apr 27, 2010 | 05:43 PM
madsonp's Avatar
madsonp
PM me with your e-mail address and I'll send you a pretty good set of instructions on how to replace it. Like was mentioned, it's a pretty intensive job but doable. It took me about 10 hours of work to do mine, and hopefully I won't ever have to do that again.
Old Apr 29, 2010 | 04:01 PM
grip1968's Avatar
grip1968
so which route should to buy the heater core, with the dealer or the local auto parts store?????
Old Apr 29, 2010 | 04:25 PM
alloro's Avatar
alloro
Whichever place offers a brass or copper one is okay, avoid the aluminum ones unless you have no choice.
Old Jun 2, 2010 | 10:51 AM
grip1968's Avatar
grip1968
do u know of any parts stores that sale the copper or brass ones??
Old Jun 2, 2010 | 01:59 PM
alloro's Avatar
alloro
These people claim to have it in stock:
FOUR SEASONS Heater Core;HEATER CORE,94808 - Autopartsnerd
Old Jun 3, 2010 | 12:09 PM
99ExpyProblems's Avatar
99ExpyProblems
I changed mine at the same time I replaced a blend door. It took me 8 hours. SUCKS!
I used alldatadiy.com for my instructions. It was still a pain in the butt! I believe on a skill level of 1-10, you should be an 8. Keep lots of sandwich bags and painters tape and mark all screws as to where they go. Do not drag it out longer than a weekend or you will be left with a mess as you will forget where some of the parts go back in!
Also, beware of the air bags. FOLLOW the instructions to keep it from deploying!
Old Jun 3, 2010 | 09:16 PM
myankow's Avatar
myankow
what they are telling you is you almost have to remove the complete Dash to exchange the Heater core. ( they mentioned 10 hrs)I live in South Florida and was lucky that i was able to bypass the heater core. I use the rear Heater to heat the vehicle the one time it got down to 40. It would have been so much simpler if the rear core went. oh yea leave out some screws when putting back together and it will squeak i am told.
kahnos
Jun 20, 2012 07:04 PM
drstrangelove787
May 1, 2005 11:22 AM
jkwarner
1997 - 2003 F150
Aug 30, 2002 04:14 PM
tkbowman
Feb 12, 2001 06:34 PM
karljay
Feb 9, 2001 07:27 PM
