01 excursion throwing some codes
Old Apr 27, 2010 | 01:49 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
The ses light has come one. I had a guy check the codes last week, one was P0720 for speed sensor, the other 3 I can't find the paper that I had written them on but were, intake heater, glow plug cylinder 1 and another speed sensor one. He cleared them but then the ses came back on. I just had him check it agian and the same codes came up but the p0720 was pending (I think). I should of wrote them down agian but I thought I had the paper from the first time. It also is cranking over slow to begin with. I have removed the intake air heater and plugged it off. This problem started when all I did was start it up move it to the other side of my truck, rotated the tires and then started it agian and that is when it through the ses light the first time. any help appreciated.
Old Apr 27, 2010 | 08:15 PM
F350-6's Avatar
F350-6
Time to ohm the glow plugs. The excursion has a GPCM so it will throw a code and trip the SES if a glow plug goes bad. Double check the code, but if it's cylinder 1 throwing the code, ohm the wire. Sounds like you might be replacing a glow plug soon (don't use autolite).
Old Apr 27, 2010 | 09:55 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
I did recently replace the gpcm because it it wasn't cutting power to the glow plugs after timing out. My 96 definitely starts better then this one
BigLoad76
Oct 6, 2021 07:20 PM
dandeee
13
Feb 2, 2012 05:34 PM
ScaldedDog
Jan 6, 2011 09:50 AM
LeeroyDiesel
Aug 6, 2009 03:54 PM
HeathJohnson
Modular V10 (6.8l)
Dec 19, 2006 07:18 AM
