Auto vs. Manual/Lock Hubs
I have a 2002 F350 Lariat Diesel 4wd. I admittedly have not engaged the 4wd system in years, so no suprise that the hub locks are frozen. I began my diagnosis and suddenly couldn't remember for certain if I have auto lock hubs or manual lock hubs. The logos have long since worn off, so I am inquiring to see what other indicators I might look for to help me correctly identify my set up. I do see what appears to be a vacuum line going to each hub so I am leaning toward the auto lock but I seem to vaguely remember seeing "Free" and "Lock" on the hubs when I bought the truck in 2003. Any reassurance would be greatly appreciated.
My 2002 F250 has the Auto/Manual hubs. Set to Auto they function as a normal automatic hub with the ESOF, but you also had the option of manually locking them into the Lock position. I suppose in case the vaccum isn't working. I think Ford still offers that same setup on the new SD hubs. I believe that counterclockwise is Auto and clockwise is Lock.
Correct including the rotation of the for the hub between and "auto and lock".
