Front Bracks
Old Jan 30, 2003 | 06:52 AM
HENDEL's Avatar
HENDEL
Post Front Bracks
I need some help, my truck pulls to the left when I apply the brakes. I replaced the left front pads and found there was nothing left of the pads and it messed up the rotor so I had to have it cut. The right side pads were OK. After doing this it still pulls to the left.
Old Jan 30, 2003 | 07:40 AM
greenpus's Avatar
greenpus
Front Bracks
When you do the brakes you have to do both right and left side. Do not just replace the pads on one side. I would replace the pads on the right side and have that rotor checked to.
If your car is still pulling to the left then you will probably have to replace or over haul the calibers.
Old Jan 30, 2003 | 10:35 AM
Ken00's Avatar
Ken00
Front Bracks
I agree, always do both sides. It could be the piston sticking in the caliper or the caliper is sticking on the slid pins.
Old Jan 30, 2003 | 11:01 PM
HENDEL's Avatar
HENDEL
Front Bracks
when i took off the the front pads off
the pads on the left side was so baddley worndown than
the other one the right side pads were still good
but i had to take the rottor had to cut left side was
there was nothin left of it i wonder if it could be
one of the calipers could be bad
Old Feb 3, 2003 | 01:43 AM
Mauser8mm's Avatar
Mauser8mm
Front Bracks
This same problem happend to my friend with a 1997 Ranger it turned out to be his callaper so I would think that your having the same problem. Good Luck!
Old Feb 3, 2003 | 03:18 AM
mathelm's Avatar
mathelm
Front Bracks
Thats the right caliper he's taking about being bad.
