360 problems
Old Apr 26, 2010 | 11:24 PM
zakk's Avatar
zakk
360 problems
just replaced intake manifold and valve cover gaskets put it all back together and it wont start. its getting a spark and fuel just wont fire. any ideas?
Old Apr 27, 2010 | 01:11 AM
Bear 45/70's Avatar
Bear 45/70
You got the distributor in wrong. Pobably 180° out.
Old Apr 27, 2010 | 08:32 PM
zakk's Avatar
zakk
so what do i need to do? i have been playin around with it a little not much has happed
Old Apr 27, 2010 | 10:46 PM
Hypoid's Avatar
Hypoid
Ford Truck Enthusiasts Forums - View Single Post - new truck
Get #1 cylinder to TDC and go from there. Bear isn't picky about which spark plug terminal #1 lands on, he can think his way through it.
Old Apr 27, 2010 | 11:11 PM
zakk's Avatar
zakk
TCD? and how would i do this
Old Apr 27, 2010 | 11:16 PM
Hypoid's Avatar
Hypoid
Old Apr 27, 2010 | 11:22 PM
Bear 45/70's Avatar
Bear 45/70
Why are you working on and engine when you have no idea of what you are doing?
Old Apr 28, 2010 | 08:03 AM
DeepRoots's Avatar
DeepRoots
althought I agree with Bear, you do need to start somewhere.
pop the spark plug out on the #1 cylinder. that'd be forward/ pass side.
feel with a peice of wire/wooden rod/etc in the cylinder as you slowly bar the engine over. When the piston is all the way up thats TDC (tho remember this is a four stroke, and so it does it twice... make sure it's on the right stroke).
buy a haynes manual at least to get some basic idea of whats going on.
best of luck,
Drew
Old Apr 28, 2010 | 08:27 AM
zakk's Avatar
zakk
well this was a project for me and my dad but he moved so im stuck and i thought i would try this place. but yeah i figured it out my dad explained it to me
Old Jun 15, 2010 | 02:37 PM
pjohnson1980's Avatar
pjohnson1980
best of luck,
Drew
or have someone trurn the crank and just put your finger over the hole to feel for the compression stroke, then use the timing mark on the dampener.
