Brake expert needed!!
https://www.ford-trucks.com/forums/9...ru-needed.html
Here is a brief synopsis of the problem:
When I make a right hand turn, after the turn the brake pedal goes soft. If I come up to a stop sign, stop, then make the turn, continue on for a few hundred feet, then brake again, the pedal goes down approx 50% further than normal. One pump and they are back up and working fine. The pedal stays firm until the next right turn.
Looked at the front brakes, re-bled them, the pins are floating fine, etc. I went ahead and did the back brakes yesterday with new rotors, pads and pins, and it still is the same.
Have also changed the front rubber brake hoses now, too!
Is this probably a master cylinder problem? I am at a loss...
HELP!!
Thanks,
Bob
