Sponsored by: Real Truck
=="HELP" 08 SD Axle Question "HELP"==
Old Apr 26, 2010 | 08:59 AM
Broncoholic1's Avatar
Broncoholic1
I have a 99 F250 SD V10 & lost the pinion last week.
I just picked up a 08 F350 SD axle & other than the difference in the rotor e-brake height. Will the 99 Calipers work on it. Is the backspace going to be the same, if I use the 08 New rotors?
I do not have the rotors yet I want to be sure before I order them.
It seems like the axle is 2" longer. I do not think it is a DRW
Axle, What is the difference in the WMS-WMS between the
SRW & DRW. Do they take different rotors?
It also has the shock mounts in a different position. '
I am going to shave the shock mounts & re weld the bolt on ones from the 99.
