PCV valve replacement in 351 EFI ... what I learned
I would definitely be doing that but I can't get the assembly off and I don't even know how it's attached on there. I was hoping someone could identify it so id know how to get it off. It slides up and down and can turn but it feels like it doesn't have enough clearance to come out.
I'm getting the same p0171 and p0174 codes. Was thinking air was leaking in through this grommet. It feels lose.
BTW: Kudos for getting that pic!! Tough angle.
same issue
Bump! Did you ever change the pcv valve? I also have that extremely annoying plastic grommet that prevents me from pulling the pcv valve. I also tried to remove just the pcv valve by loosening the hose clamp. NO-Way, it is melted onto the pcv valve (guess it has never been changed). I thought this was going to be an EZ fix. Yeah right.
1972-34ton
22
03-28-2023 08:17 PM
annaleigh
04-19-2016 02:28 AM
annaleigh
11-20-2015 10:30 PM
78_79ford
26
08-28-2015 08:50 PM
