Injector Cup R&R
No worries man, I didn't come up with it. I just wanted something to offer customers so that they could swap them in the truck and not have to buy a tool. Not perfect but better than other options.
DIY-Injectors.com Click on the Injector tools link. His appears to use a threaded puller.
But the loaner set from Clay was free. Hard to beat that price.
Thanks Trevor. A much, much better buy then from Whitaker Tools
Kudos, lauds, and the singing of praises would officially be in your reputation folder, Robin, but alas, the powers above have thwarted me by a technique designed to prevent the over-use of that system. Shucks! Haveta' catcha' next time....
Yes, I grabbed the PDF last night, but over-wrote it this morning. I didn't look to see if the duplicate paragraph was in the original or not, but figured if you dropped it from here, you got the other, too.
Hopefully, I'll never have to make use of that info (I'm still using the green), but if I do, yours will be the reference guide, including stripping the head down as you did. Great work!
But that's your norm!
Pop
Pop
Pop
Pop
Thanks for the kind words and Take Care Pop.
Pop
#29
BTW anybody need any SCA test strips? I think they are still sitting in my shop.
EDIT- strike last offer, they expired in 2008....
#30
I bet they still work fine. If someone needs them, you can send me one of the strips and I'll test it side by side with a fresh strip in my tractor. Not fool proof, but if it's an exact match, it's better than nothing, and I'm guessing pretty accurate.
