Exceeding the payload capacity
And then would I be required to have a CDL?
-Matt
Now take the truck to a set of scales and get the lite weight.
Subtract the lite weight from the registered gross weight and you have your legal payload weight limit.
Your lite weight should include passengers, fuel and everything you normally carry when you are hauling your wood.
Commercial plates and insurance cost about 5 times what regular plates cost.
Or put it another way, they cost about what one overweight ticket would cost.
If you pull a trailer, the truck plate gross weight needs to be equal to or above the weight of the truck, passengers, trailer and all cargo on both vehicles weigh.
RV's are exempt from this.
check here:
http://www.dol.wa.gov/vehicleregistr...tvehweight.pdf
where i am,the truck's weight alone puts me above passenger plates lol.so id be breaking the law every time i tried going anywhere just running empty if i registered it as a passenger vehicle.
its important to know your local laws:
http://www.dol.wa.gov/vehicleregistration/fees.html
There are two options for the Commercial plates:
)Commerce gets real expensive real fast.
-Enjoy
fh : )_~
Here's the table for personal registration:
And if i want commercial registration, here's the table for those:
http://www.dol.wa.gov/vehicleregistr...rossweight.pdf
So I'm a little bit confused still but it looks like either way i go, to declare it at 12,000 pounds i'm somewhere under $100.
I think i'm going to buy a trailer and haul 1 chord on the truck and up to 2 on the trailer. It'd be nice to have a heavy dual axle flatbed trailer anyway, to haul my '67 mustang around on.
So if we say my truck weighs 6,000 LBS
My plates are registered for 8,000 LBS
And I have a trailer that weighs in at 7,000 LBS loaded
A. Does that mean to hook the 7k lb trailer up to my 6klb truck I should really have my truck licensed for 13K or better?
B. OR, is it as long as the weight of the truck plus the tongue/gooseneck/5th wheel load on the truck is less than 8K I'm ok?
Thanks for clearing it up!
Chris
Chris
A trailer that would be towed behind a pickup, one plate cost, no weight listed on the registration.
A trailer that would be towed behind a semi, one plate cost, no weight listed on the registration.
The power unit has to be registered for the gross weight of the entire vehicle as it is rolling down the road.
So when you pull on the scales, all passengers, fuel and cargo are part of the gross weight of the vehicle.
Way back when I started driving cross country, this state had this law for axle weight, total weight, length and height.
As soon as you crossed to the next state those limits were probably different.
In the 80's most states went to 80,000 pounds for a 5 axle semi with axle limits of 34,000 on the tandems and 20,000 on the steering axle except Illinois, Missouri and Arkansas which stayed at 73,280 pounds gross with 32,000 on the tandems and 20,000 on the steer axle.
So the western shippers all wanted you at 80,000 gross when you left there, the consignee's all wanted 80,000 pounds gross when you got to your delivery point since they got more shipped for less money.
So that left us poor truckers out there running scales taking big detours to get across the center of the country.
Course when they caught you, the fine came out of the owner operators pocket.
Nothing more than a big cash cow for the states that stayed at 73,280 pounds gross weight.
Out west bridge laws were used to determine how much weight you could carry, long trucks could carry more weight.
Back east, with the narrow roads, tight congested cities overall lengths were restricted to 50 or 55 feet, or slightly more than the 52 foot trailers they are running today.
Add all the fuel stickers you had to have to run through each state since you may buy more fuel than you used in that state and less than you used in the next state you were basically paying to import or export fuel from each state.
Pa. was 309 miles across, so I better buy 61.8 gallons of fuel in Pa.
Ohio was 223 miles across, so I had to buy 44.6 gallons there.
Indianna was 156 miles across, so I had to buy 31.2 gallons there.
If I did not buy that amount of fuel, I had to pay the highway use tax on the fuel I burned in each state that I imported from another state.
However the state I bought to much fuel in would refund the highway use tax on the fuel I bought there that was over and above what I burned there, course the refund came with the lightning speed of your income tax return in those days, 4 or 5 months.
So you think things are confusing today, you should have been out there in the 70's.
Moral of the story, check with the DMV of any state you plan on running through with a trailer or loaded truck if it looks like it may be business use.
There is a 99.2% chance that you not knowing the laws will cost you money when you cross a state line.
