99 gear recommendation?????
My future plans are probably to do a 4" suspension lift but I don't think that will affect the gear sizing. In the future, not any soon for financial reasons, I hope to install a HD takeoff supercharger kit. So I hope to add a lot of HP and I only am going to change the gears once. I don't want anything too aggresive that will cause any problems and significantly decrease MPG. I also don't plan on doing any transmission work any time soon. If I need to, I may do some minor trans work when I install the SC, but not anytime soon.
I used to have a 89 and 91 Mustang 5sp and had 3.55, 3.73, 4.10. So if this F150 was a Mustang, I would like to install 3.73 but their still is the difference between the 5sp 5.0 and the F150 is auto so it still is hard to compare. Does that translate into 4.30 for the F150?? What ratio would everyone recommend for my truck now and once it is supercharged? Hopefully it is the same ratio since I am only changing the gears once. If the ratio should definitely be different then maybe I should wait to change the gears until it is supercharged. I just want to feel a power increase and I can't afford to supercharge it now with all the other parts needed to do it properly. If I install 4.30 now, will it feel much faster?
What are the main ratio's for MY truck, 4.10, 4.30 and 4.56??? If so, can someone tell me the RPM @ 70 MPH for each ratio with stock tranny and 33" tires?
So were you recommending the 4.56 for current condition and the 4.10 for when it is supercharged?
