Help finding cylinder head numbers.
Old 04-24-2010, 07:52 PM
raerjim's Avatar
raerjim
raerjim is offline
Can someone tell me where I can find these numbers on an already mounted head? This is an early 70's 351W. BTW, what can you tell me about BLOCK casting number: D9AE-8015-ED_15
2E 22
I think the 2E22 (stamped after casting) is May 22, 1972
Old 04-24-2010, 10:59 PM
Julies Cool F1's Avatar
Julies Cool F1
Julies Cool F1 is offline
Here's a good site for decoding Ford Part Numbers:
Guide to Decoding Ford Part Numbers - ClassicMustang.com
I copied this from a site - maybe you can tell from this what you need to know:
This is a quick way to reference what you are looking at by using visual clues.
1.SB Ford heads were made from a range from 1962-2000.
2.Cubic inch displacement ranged from 221-351W.
3.Ford used three types of rocker arm setups.
Look for the displacement casting number
The first thing you have to do is pull a valve cover and look for the displacement casting number. Ford was pretty good about casting displacment numbers, but they didn't do it on all engines. There will be two pre-'77 engines that Ford did not do this on. The engines will be the 221, 260. The rest of the pre-1977 SB Ford engines will have a 289, 302 and 351 cast on the top of the head under the valve cover. Post-'77 engines did not cast displacement numbers, only a casting number on the deck side.
Heads without displacement casting numbers
So what if you want to know what year of 289, 302 or 351W head you have or if you have 221, 260 or 255 heads? Use your visual clues to identify what head you have. First off, if you have a head with no casting displacment number on it, then it must be a 221, 260 or a post 77 255, 302, 351W head. So which one do you have? Look at the rocker arm. If you have a conventional rocker arm with a machined slot in the head for a push rod, you have a 221 or a 260 head. If the head has a bolt down sled fulcrum, with a large hole drilled for the pushrod, then it is a post-'77 255, 302, 351W head.
Next, Ford used two different rocker arms setups for the 289, 302, and 351W and one rocker arm design for the 255. The 289 used a conventional rocker and a rail type of rocker arm. The 302, 351w used a rail rocker arm and a bolt down sled fulcrum. The 255 used only the bolt down sled fulcrum type of rocker arm. The 289 used the conventional rocker arm up to mid 1966 and then switched to the rail rocker arm design. So, if you pull a valve cover and it says 289 and has a conventional rocker arm, it is a pre-'67 head. If it has 289 under the valve cover and it has rail rockers, it is a 1967-68 289 head.
ID'ing a 302 head
Let's ID a 302 head. If you pull the valve cover and it has 302 then it is a 302, but what year is it? Ford used two designs of rockers for the 302, rail and sled fulcrum. If you have a 302 with rail rocker arms it is a 1968-1977 head. If you have a head with no displacement casting numbers and bolt down sled fulcrum rockers, then you have a post 77 255, 302, 351W head. The 351W will follow the same basic rules as the 302. So what is the exact year for 302's and 351W's without having the exact casting numbers?
The 302's are the tricky ones, so here is how to look for visual clues. In 1968 Ford, used adjustable rail rockers on 302's; the rest were non-adjustable. To tell if you have a 1968 302, look at the rocker arm studs. If the stud is not shanked down at the threads it is a '68 302 head. In 1969, Ford changed rocker studs to a non-adjustable setup; the stud thread will be shanked down. The post '68 302 will also use a smaller rocker retaining nut than the 1968 302 head. So if you have a shanked down stud and rail rockers on your 302, it is a 1969-1977 head. This is close but not close enough, so how do you narrow it down? Again use visual clues to determine what year of head you have.
In 1975 Ford went to internal smog ports on the the SB heads with a tube connecting both heads together going to the smog pump. So if you have a 302 casting number with rail rockers and tubes on the back of the heads connecting them together, you have a 1975-1977 302 head.
ID'ing a 351 head
The 351W is quite a bit easier, but it has some quirks. If it says 351 on the top of the head below the valve cover and has rail rocker arms it is a 1969-1977 351W head. The 1969-1977 351W head will use 16 intake manifold bolts as opposed to 12 for the 221, 260, 289, 302 and 255. In 1978, Ford made both the 302 and 351W head interchangeable with no displacement numbers cast on them.The last part is how to determine a 255 from the 302 and 351W head. The 255 will use small oval ports as opposed to the rectangular ports of the 302-351W. The only way is to pull either the intake or a exhaust manifold. If it has oval ports its a 255, rectangular ports it a 302-351W.
Hope that helps!
Old 04-25-2010, 12:09 AM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,521 Likes on 1,437 Posts
2E 22
Your block is newer than you think. The first 2 characters of your casting number identify when the engineering was done, and in your case D9 indicates 1979. That means your block wouldn't have been cast prior to the 1979 model year. Now we look and your casting date code, 2E22. Since the block wouldn't have been cast 7 years prior to it's engineering, your date code has to be May 22, 1982.
Small block heads have their cast identifiers located next to the head-to-block mounting face, between the pushrod holes. The only way you can read them with the heads installed is with a mirror from inside the valley with the intake removed.
Old 04-25-2010, 05:06 PM
raerjim's Avatar
raerjim
raerjim is offline
Thanks Guys. I try to learn something every day.
907outdoorsman
1997 - 2003 F150
01-27-2013 09:38 PM
drew.law
01-23-2011 05:23 AM
FordTrucksKickGM
06-29-2006 05:05 PM
oldiron
02-18-2006 07:17 PM
plowd1
09-02-2002 05:38 PM
Quick Reply: Help finding cylinder head numbers.
