Trouble Codes
Old Apr 24, 2010 | 07:52 PM
ken_wied's Avatar
ken_wied
Trouble Codes
Hey all,
I had my 98 ranger in storage for 2 years. Now, its back up and running. Recently the CEL came on. It showed P1131 Fuel Air Metering. What should I be looking for? I can pull the battery lead and it comes back on within hours. Its the 4.0 liter engine.
Thanks
KEn
Old Apr 24, 2010 | 08:13 PM
khadma's Avatar
khadma
Carpenter Local 745
P1131 is a Ford specific
DTC.
Lack of heated 02 sensor switch
Here is a related thread
It is a different truck, but items to check will be similar.
Start with the O2 sensor then check for damaged or leaking hoses or fittings.
https://www.ford-trucks.com/forums/6...71-0174-a.html
Old Apr 25, 2010 | 07:58 AM
pawpaw's Avatar
pawpaw
Additionally, it's the up stream bank 1 (passenger side) O2 sensor & it's indicating lean.
Could be an exhaust leak, lower intake manafold gasket leak, acting out O2 sensor, or maybe a wiring problem to it.
Seeing as how it's been in storage for a while, maybe do an intake manafold leak check & if you come to suspect it, maybe consider trying a retorquing of it's fastners.
Check the bank one exhaust manafold & down pipe to the O2 sensor for leaks also.
Let us know what you find.
ken1mod
Aerostar
Nov 15, 2005 10:16 AM
Bargod
Kansas Chapter
Aug 2, 2005 10:35 PM
dogman
Computer Chips & Tuners
May 31, 2005 05:38 PM
COBRAjrb
1978 - 1996 Big Bronco
Feb 19, 2004 04:14 PM
FTE Ken
Site Announcements
Mar 9, 2001 01:22 PM
